Touch systems
Quelle: Distec | Lukas Dehling,
Install without mounting bracket
Distec presents the new POS-Line V2 series with industrial monitors from 15 to 24 inches. According to the manufacturer, their aluminum housing offers a robust, high-quality powder-coated surface.
© Distec
This reduces the overall weight of the monitors by around 50% compared to the previous version. It also enables use in ambient temperatures of up to 60 °C and offers front-side IP protection up to IP65 thanks to the closed housing. The new front options can be connected to the OpenFrame devices without a mounting bracket. The PCAP touch technology recognizes up to 10 fingers simultaneously. The PrismaMEDIA-ECO video card offers DisplayPort, HDMI and VGA connections. The manufacturer is also showing suitable PC platforms for the new series: in the lower performance range, an Atom Baytrail architecture with 4 CPU cores. Current Core i5/i7 CPUs are available in the upper performance range. Distec can install a Windows operating system ex works on request.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
