Graphic terminals
Quelle: Rockwell Automation | Lukas Dehling,
Including 19-inch format
Rockwell Automation presents the Allen-Bradley Panelview Plus 7 Performance graphic display terminal, which is designed to simplify and optimize visualization in large, complex systems.
© Rockwell Automation
The graphic display terminal extends the Panelview Plus 7 family and is available in six screen sizes, including a new 19-inch format - the largest currently available from Rockwell Automation. The model also includes new keyboard features to complement the standard touchscreen. While the standard model supports applications with up to 25 screens and 200 alarms, the performance model is suitable for larger and more complex applications thanks to a more powerful CPU, according to the manufacturer. Thanks to the additional embedded Ethernet switch technology with two Ethernet ports, the graphic terminal can support a device-level ring (DLR) topology for higher availability. The graphic display terminal also offers enhanced mobile connectivity. Remote Desktop Services enable operators and plant managers on the production floor to connect to the central company systems, such as ERP or MES, via a thin client connection.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
Kontron
Control panel series updated
Kontron has developed a new generation of its Control Panels which, thanks to the more powerful Arm NXP i.MX8M Plus processors, provide a significant performance boost compared to previous models.
