Readout and parameterizationThe NFC alternative
NFC can be found in more than 1.5 billion smartphones and is primarily used in the consumer sector. The simple and intuitive communication over short distances also predestines the technology for industry.
<p>With the 'Mini Analog Pro' isolating amplifier from Phoenix Contact, signal ranges, sampling rates, user-specific characteristics and device labels can be set via NFC smartphone. Measured values can also be viewed.</p><p><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves></w:TrackMoves>
<w:TrackFormatting></w:TrackFormatting>
<w:HyphenationZone>21</w:HyphenationZone>
<w:PunctuationKerning></w:PunctuationKerning>
<w:ValidateAgainstSchemas></w:ValidateAgainstSchemas>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:DoNotPromoteQF></w:DoNotPromoteQF>
<w:LidThemeOther>DE</w:LidThemeOther>
<w:LidThemeAsian>X-NONE</w:LidThemeAsian>
<w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
<w:Compatibility>
<w:BreakWrappedTables></w:BreakWrappedTables>
<w:SnapToGridInCell></w:SnapToGridInCell>
<w:WrapTextWithPunct></w:WrapTextWithPunct>
<w:UseAsianBreakRules></w:UseAsianBreakRules>
<w:DontGrowAutofit></w:DontGrowAutofit>
<w:SplitPgBreakAndParaMark></w:SplitPgBreakAndParaMark>
<w:EnableOpenTypeKerning></w:EnableOpenTypeKerning>
<w:DontFlipMirrorIndents></w:DontFlipMirrorIndents>
<w:OverrideTableStyleHps></w:OverrideTableStyleHps>
</w:Compatibility>
<m:mathPr>
<m:mathFont m:val="Cambria Math"></m:mathFont>
<m:brkBin m:val="before"></m:brkBin>
<m:brkBinSub m:val="--"></m:brkBinSub>
<m:smallFrac m:val="off"></m:smallFrac>
<m:dispDef></m:dispDef>
<m:lMargin m:val="0"></m:lMargin>
<m:rMargin m:val="0"></m:rMargin>
<m:defJc m:val="centerGroup"></m:defJc>
<m:wrapIndent m:val="1440"></m:wrapIndent>
<m:intLim m:val="subSup"></m:intLim>
<m:naryLim m:val="undOvr"></m:naryLim>
</m:mathPr></w:WordDocument>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"
DefSemiHidden="true" DefQFormat="false" DefPriority="99"
LatentStyleCount="267">
<w:LsdException Locked="false" Priority="0" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Normal"></w:LsdException>
<w:LsdException Locked="false" Priority="9" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="heading 1"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 1"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 2"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 3"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 4"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 5"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 6"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 7"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 8"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 9"></w:LsdException>
<w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"></w:LsdException>
<w:LsdException Locked="false" Priority="10" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Title"></w:LsdException>
<w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"></w:LsdException>
<w:LsdException Locked="false" Priority="11" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtitle"></w:LsdException>
<w:LsdException Locked="false" Priority="22" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Strong"></w:LsdException>
<w:LsdException Locked="false" Priority="20" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="59" SemiHidden="false"
UnhideWhenUsed="false" Name="Table Grid"></w:LsdException>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"></w:LsdException>
<w:LsdException Locked="false" Priority="1" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="No Spacing"></w:LsdException>
<w:LsdException Locked="false" Priority="60" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Shading"></w:LsdException>
<w:LsdException Locked="false" Priority="61" SemiHidden="false"
UnhideWhenUsed="false" Name="Light List"></w:LsdException>
<w:LsdException Locked="false" Priority="62" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Grid"></w:LsdException>
<w:LsdException Locked="false" Priority="63" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 1"></w:LsdException>
<w:LsdException Locked="false" Priority="64" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 2"></w:LsdException>
<w:LsdException Locked="false" Priority="65" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 1"></w:LsdException>
<w:LsdException Locked="false" Priority="66" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 2"></w:LsdException>
<w:LsdException Locked="false" Priority="67" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 1"></w:LsdException>
<w:LsdException Locked="false" Priority="68" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 2"></w:LsdException>
<w:LsdException Locked="false" Priority="69" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 3"></w:LsdException>
<w:LsdException Locked="false" Priority="70" SemiHidden="false"
UnhideWhenUsed="false" Name="Dark List"></w:LsdException>
<w:LsdException Locked="false" Priority="71" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Shading"></w:LsdException>
<w:LsdException Locked="false" Priority="72" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful List"></w:LsdException>
<w:LsdException Locked="false" Priority="73" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Grid"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 1"></w:LsdException>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"></w:LsdException>
<w:LsdException Locked="false" Priority="34" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"></w:LsdException>
<w:LsdException Locked="false" Priority="29" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Quote"></w:LsdException>
<w:LsdException Locked="false" Priority="30" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 6"></w:LsdException>
<w:LsdException Locked="false" Priority="19" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="21" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="31" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"></w:LsdException>
<w:LsdException Locked="false" Priority="32" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"></w:LsdException>
<w:LsdException Locked="false" Priority="33" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Book Title"></w:LsdException>
<w:LsdException Locked="false" Priority="37" Name="Bibliography"></w:LsdException>
<w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"></w:LsdException>
</w:LatentStyles>
</xml><![endif]--><!--[if gte mso 10]>
<style>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Normale Tabelle";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin-top:0cm;
mso-para-margin-right:0cm;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0cm;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-fareast-language:EN-US;}
</style>
<![endif]--></p> © Phoenix Contact
