HMI devicesNode programming thanks to Node-RED
The JSmart IoT Web-Based HMI device from Exor with PCAP multi-touch offers protection class IP69K. With the patented mounting via a standard 22 mm hole, the 12.5 mm thick display can be easily mounted anywhere on a machine or system.
