Current productsNews about operating and monitoring
What does the optimum operating unit for industrial users look like? What's happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
9 of 31
Touch Panel PC AFL3-W22C-ULT3 Industrial Computer Source
© Industrial Computer Source
The AFL3-W22C-ULT3 is a touch panel PC from Industrial Computer Source that offers flexible power supply options with a wide range input from 9 V to 36 V(DC). It is available with a pre-installed Intel Skylake Core i5 or Celeron processor. Two DDR4 SO-DIMM with up to 32 Gbyte memory capacity are available. Further storage options are available via 1x 2.5 inch SATA 3 Gbit/s HDD, 1x m2M PCIe and 1x mSATA. The range of interfaces and extensions includes COM, GbE LAN, USB3.0, HDMI, power switch, AT/ATX switch and audio. The Panel PC is equipped with an IP64 waterproof front panel with a flat design. As the heat dissipator of the fanless panel is located at the rear, the system is easy to clean. With a screen diagonal of 21.5 inches, the device supports a maximum resolution of 1920 x 1080 pixels with a brightness of 250 cd/m", a contrast ratio of 1000:1 and 16.7 million colors.
9 of 31
