Current productsNews about operating and monitoring
What does the optimum operating unit for industrial users look like? What's happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
31 of 31
TBT-A11-056TLC D2 from Incostartec
© Incostartec
The TBT-A11-056TLC D2 touch operating terminal from incostartec consists of a 5.6 inch VGA TFT touch display and a modular system. The low-cost version is equipped with the "picolilly" processor module with ARM1135/ 532 MHz - expandable with Cortex A8/A9 with up to 1.2 GHz. A DRAM memory with 128 Mbytes ensures fast data processing. In addition to a 32 Mbyte flash memory, an internal μSD card slot and an external SD card slot, which is protected by a sliding cover, are available as standard. The interfaces of the D2 variant include 2x USB 2.0, 1x RS232 and 1x Ethernet. In addition, the following optional peripheral options are available: 2x serial IF RS232/485, CAN-BUS, I²C-BUS, free GP I/Os, WiFi/BT and GSM/GPS. These are implemented according to customer requirements via the AUX expansion module. Various interface connectors on the rear of the device can be led out at the bottom. The operating terminal can be mounted at the place of use with a 2-point fixation or optionally with a 75x75 VESA fixation. The supply voltage is 9 to 39 V.
31 of 31
