Touch monitors
Quelle: Advantech Europe | Inka Krischke,
Front protected to IP65
Advantech launches the IDS-3300 industrial touch monitor series with IP65-protected front and screen sizes of 10.4 inches, 15 inches and 19 inches. The monitors are equipped with robust front metal frames developed in-house.
© Advantech Europe
The series offers a wide range of surface options for various application and user scenarios, including cover glass, resistive touchscreen and projected capacitive touchscreen. Customization services are also offered, such as brightness optimization and AR coating for outdoor applications. The touch monitors are resistant to water, dust and moisture and are particularly suitable for the food and beverage industry as well as outdoor applications. The series is equipped with a VGA/DVI/HDMI signal interface for easy integration into all embedded boards and systems. USB and RS232 ports enable connection to various touchscreens.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
