Display devices
Quelle: ACS-Control-System | Lukas Dehling,
For mounting on a standard mounting rail
The digital display unit DPA is designed for front panel mounting or on-site installation or for mounting on a standard mounting rail.
© ACS Control System
The applied electrical standard signal in the range of 0 to 10 V or 0 to 20 mA is detected by the evaluation circuit, adapted according to the programmed settings and transmitted electrically isolated to the output signal 0 to 10 V or 0/4 to 20 mA. Thanks to the possibility of entering 40 interpolation points, non-linear input signals, for example from horizontal cylindrical containers, can also be linearized for further processing. Up to four freely programmable relay switching points can be assigned to the input signal. The process indicator is not only suitable for level measurements but also for recording and measuring flow rates and flows. The mathematical formulas for this are already stored in the device. The TFT color display ensures that the measured values are displayed and easy to read. Intelligent data management is made possible with the DPA digital display device by the Bluetooth interface and a built-in data logger function with time stamp for recording up to 500,000 measured values.
