HMI editor
Quelle: Ininet Solutions | Lukas Dehling,
Enables browser-based programming
Browser-based programming is possible with the web HMI construction kit Spidercontrol from Ininet. On the right-hand side of the tool there is a theme catalog, in the lower area the objects of the selected theme are displayed and described if necessary.
© Ininet Solutions
The user can insert these into their current page from here. The various objects can also be moved and resized or parameterized within the page. This means that all elements of the Web HMI Editor can be used and combined to suit the individual customer. All components of the Web HMI Editor are drawn using the PC-based editor. Each desired object is graphically designed and grouped on the PC, and the parameters required for configuration in the Web HMI are marked. The selected parameters then appear in the Web HMI Editor as properties of the object and can be easily adjusted by the user in the field.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
