HMI editor
Enables browser-based programming
Browser-based programming is possible with the web HMI construction kit Spidercontrol from Ininet. On the right-hand side of the tool there is a theme catalog, in the lower area the objects of the selected theme are displayed and described if necessary.
The user can insert these into their current page from here. The various objects can also be moved and resized or parameterized within the page. This means that all elements of the Web HMI Editor can be used and combined to suit the individual customer. All components of the Web HMI Editor are drawn using the PC-based editor. Each desired object is graphically designed and grouped on the PC, and the parameters required for configuration in the Web HMI are marked. The selected parameters then appear in the Web HMI Editor as properties of the object and can be easily adjusted by the user in the field.
