Distec
Change in management
Distec, supplier of industrial TFT flat screens, embedded products and system solutions, announces a change in management.
The new Distec dual leadership: Ulrich Ermel and Matthias Keller (from left)
© Distec
On March 1, 2023, Ulrich Ermel took over the position of Managing Director from Bernhard Staller, who is retiring. Ermel takes on a dual role as Managing Director of Distec and COO of the parent company Fortec Elektronik. Matthias Keller will remain on the management board, so that a dual leadership team will continue to be available as contact persons.
Ermel holds a degree in electrical engineering (FH) and a diploma in engineering and has extensive management skills and leadership qualities as well as expertise in the areas of power supplies and embedded systems.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
