Support arm systems
Carries loads of up to 130 kg
The new MIT support arm series from Haseke carries loads of up to 130 kg. The support arm system made of extruded aluminum profile can be combined with the well-known HLT support arm system and the height-adjustable support arms HMA Lift 25, 350 and 380 as well as 501.
With the manufacturer's modular system, the HMA MIT can also be freely configured for different applications and is therefore ideally suited for new equipment and retrofitting. With the maintenance-free system, the inclination, stiffness and rotation range limitation can be adjusted from the outside. The support arm system offers a cable aperture of 70 × 50 mm, is suitable for lengths up to 2500 mm and is IP54-tested.
