Panel PCs
Quelle: Electronic Assembly | Lukas Dehling,
Capacitive or resistive touch
With its new touch panel series, Electronic Assembly offers both capacitive and resistive touch with identical functionality.
© Electronic Assembly
The display automatically acknowledges inputs via the touchscreen with various signal messages, the change of an output level or with data via one of the built-in RS232, SPI or I²C interfaces. Its scratch-resistant and dirt-repellent surface is designed to ensure a long-lasting, clear appearance. All operating elements can be dynamically adjusted during operation and the panels are available in 3.2 inch, 4.3 inch, 5.7 inch and 7 inch sizes, depending on the installation situation. The displays can be soldered in, screwed in or plugged in. They also each have eight digital inputs and outputs as well as two programmable analog inputs. They are controlled via high-level language-like graphic commands. The long-life LED lighting has been specially developed for applications in industrial environments.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
Kontron
Control panel series updated
Kontron has developed a new generation of its Control Panels which, thanks to the more powerful Arm NXP i.MX8M Plus processors, provide a significant performance boost compared to previous models.
