Bosch Rexroth
With magnetic measuring principle
The integrated position measuring system 'IMS' from Bosch Rexroth is now also available as 'IMScompact' for absolute measurement.
© Bosch Rexroth
The non-contact solution with magnetic measuring principle enables position detection for linear guides of different lengths and sizes and thus completely replaces external linear position measuring systems. The system completes the existing portfolio of integrated measuring systems from Bosch Rexroth, which also includes an incremental measuring 'IMScompact' and two inductive high-end variants for high-precision applications. The position of the carriage is measured without contact with an absolute accuracy of +/-20 µm/m and a repeatability of +/-1 µm at speeds of up to 5 m/s. The measuring length can be up to 17.8 m with multi-part rail sections. The system integrated in the carriage is available in sizes 15, 20 and 25. The advantage of the absolute measuring function over the incremental function is that the system is ready for use immediately after switching on or after a power failure.
Partnership
Wago relies on Bosch Rexroth
Wago will be the first system and technology partner to use the real-time capable, Linux-based operating system 'ctrlX OS' from Bosch Rexroth on future controllers in the medium and high performance classes.
Bosch Rexroth
ctrlX Automation ecosystem
The real-time capable, Linux-based operating system ctrlX OS from Bosch Rexroth, which was previously used exclusively on the ctrlX Core controller, is now available as a separate solution for the industrial environment.
Kistler
Solid sales development in 2025
The Kistler Group generated sales of 424 million Swiss francs in 2025. With a currency-adjusted decline of 1 percent, or 5 percent in Swiss francs, the company was able to keep sales stable compared to the previous year.
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
