Current clamps
With integrated thermal imaging sensor
Flir has announced the launch of the CM174 Thermal Current Clamp with infrared measurement aid technology and integrated thermal imaging sensor.
This is designed to visually alert the user to temperature differences and anomalies. The narrow clamp and integrated work light are designed to make it easier to work in confined areas with hard-to-reach cables and poor lighting conditions. The CM174 checks the results with advanced measurement functions which, according to the manufacturer, help the user to rectify even complex electrical problems. At the same time, it is intended as a tool to check that repairs have been carried out correctly and to ensure that the repaired areas are working again.
