Current productsNews from measurement technology
What innovations are there for industrial users on the measurement technology market? Computer&AUTOMATION has summarized a selection of products that can also be seen at Sensor+Test 2019 in a series of pictures
3 of 7
EE310 and EE360 industrial transmitters from E+E Elektronik
© E+E Elektronik
The EE310 and EE360 industrial transmitters from E+E Elektronik are available with stainless steel or polycarbonate housings. The 'EE310' humidity and temperature transmitter is used to monitor and control industrial processes, while the 'EE360' determines the moisture content of industrial oils and thus enables predictive maintenance of machines and systems. Both transmitters have an optional 3.5-inch TFT color display to show the current measured values. The integrated data logger stores up to 20,000 measured values per measured variable. The recorded data can be shown directly on the display as a curve diagram or downloaded for further analysis via a USB interface. Two analog outputs and an optional RS485 interface (Modbus RTU) or Ethernet interface (Modbus TCP) are available for measured value output. Two additional relay outputs can be used for alarm or control purposes. The housing design makes it easy to install and maintain the transmitters: the upper housing section with measuring electronics and sensor connections can be replaced in a few simple steps, while the cabling in the lower housing section remains unaffected.
3 of 7
