Displacement measuring systems
Quelle: Micro-Epsilon Messtechnik | Inka Krischke,
Classified according to protection class IP68
The capaNCDT 61x0/IP is a capacitive displacement measuring system from Micro-Epsilon designed for quality assurance in production processes and for machine and system control.
© Micro-Epsilon measurement technology
The IP68-rated measuring system is insensitive to temperature fluctuations and magnetic fields. It is used for non-contact measurement of variables such as displacement, distance, deflection, expansion and deflection on conductive measurement objects. The system consists of a sensor, a sensor cable and a controller. Thanks to factory calibration, it is ready for immediate use. Recalibration is not necessary even if the sensor is subsequently replaced. Data is output via current or voltage or the digital RS485 interface. The die-cast aluminum housing protects the controller from dust and moisture, while the sensor cable ensures slip resistance and temperature resistance. With flat, cylindrical and threaded sensors, three different sensor types are available to choose from depending on the installation situation.
Micro-Epsilon
Confocal chromatic precision sensor
The confocal chromatic sensor 'IFS2407-1.5' expands Micro-Epsilon's 'confocalDT' sensor portfolio and is used for high-precision displacement and thickness measurement. The sensor has a measuring range of 1.5 mm with a base distance of 17 mm.
