Measuring systems
Quelle: SeLasCo | Lukas Dehling,
Analysis of structure-borne sound
Selasco will be demonstrating a system for non-contact and non-destructive wear and defect diagnosis of power units during operation.
© SeLasCo
With the help of a laser beam, characteristic sound spectra of a unit to be monitored (e.g. high-performance pump, motor, gearbox, machine, drive unit, turbine) are recorded in a frequency range from infra- to ultrasound in the MHz range using interference measurements. The structure-borne sound generated during operation is then analyzed using mathematical algorithms. Level differences between the current evaluated signal and a reference signal are intended to indicate a material defect in the monitored component. According to the manufacturer, this enables material changes to be detected at an early stage and total failure to be avoided.
Kistler
Solid sales development in 2025
The Kistler Group generated sales of 424 million Swiss francs in 2025. With a currency-adjusted decline of 1 percent, or 5 percent in Swiss francs, the company was able to keep sales stable compared to the previous year.
Althen
Change in management
Althen Mess- und Sensortechnik will be managed by Edwin Goezinne in the future. He succeeds Dr. Timo Hartmann, who was at the helm of the company in Germany for six years.
