Iba
A new generation of condition monitoring solution
With 'ibaCMS', Iba is presenting a completely revised condition monitoring solution following the acquisition of Hainzl's condition monitoring division in summer 2023.
© iba
The core of the system is the web-based desktop application 'ibaCMC' for trend analysis, alerting and reporting tasks. It is used by maintenance staff, users, operators and operators of industrial and production plants to detect damage at an early stage in order to reduce repair costs, reduce the number of unplanned production downtimes and improve the production process itself. The architecture of the condition monitoring system consists of one or more modular 'ibaDAQ' systems with the basic software 'ibaPDA' (Process Data Acquisition) and the new 'ibaCMC' (Condition Monitoring Center), which is based on an Angular framework and HTML5. As a replacement for the discontinued 'ibaCMU-S', the ibaPDA-based ibaDAQ is available as a condition monitoring device (CM device for short). According to Iba, this flexible system architecture significantly improves the possibilities of monitoring methods and evaluation algorithms.
Digitization
Cooperation between ifm and Schuler
In order to monitor and improve quality in press shops through digitalization, ifm and the Schuler Group have entered into a cooperation agreement. The aim is to offer customers greater transparency and increase efficiency in sheet metal forming.
Oriental Motor
For predictive maintenance
According to the manufacturer, the new incremental encoder from Oriental Motor is particularly suitable for use in predictive maintenance thanks to its precision in measuring speed, position and direction of rotation.
E-T-A
Sensory in view
Intelligent power distribution systems are valuable helpers when it comes to digitalization in the IT rack. Monitoring the IT racks using sensors is a particularly effective measure for increasing system availability.
Balluff
Condition monitoring in the sensor
Whether conveyor belt, industrial robot, hydraulic unit, motor or pump - the failure of individual components can bring the entire system to a standstill. This makes condition monitoring all the more important - for example using a condition...
