SCADA software
Quelle: Copa-Data | Lukas Dehling,
Reduce the error rate
Copa-Data shows that modern paper-on-glass technology offers many advantages. The Zenon software's Smart Checklist not only makes the work of production staff easier and reduces the error rate.
© Copa-Data
According to the manufacturer, the data can be processed immediately and used for reports and key figures. Only when data is available digitally can it be analyzed, interpreted, patterns identified and probable developments calculated. Production can then learn from past processes and its own procedures and prevent machine failures, for example. Together with Resolto Informatik, Copa Data shows how hidden knowledge can be harnessed and developments identified at an early stage so that the right measures can be taken at the right time.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
