Lucom
No need for manual router configuration
'Digicluster' is a VPN service portal from Lucom in which complete networks, machines, systems and control centers are flexibly connected with each other.
VPN service portal 'Digicluster' from Lucom
© Lucom
Mobile and LAN-to-LAN routers connect directly to the service portal via a virtual private network. Manual configuration of the routers is not necessary. Access rights are structured in the 'Digicluster' via group and user rights. For example, identical machines and systems with the same IP addresses can be networked with each other via 1:1 NAT.
The VPN service portal is available as a hosted solution in the data center, as a virtual machine (VM) or directly on IPC hardware. The number of connections is scalable and therefore suitable for establishing one to more than 1000 connections per system. The individual accesses to the VPN service portal enable full network routing for a Lucom VPN router or any Teleworker VPN client (PCs, smartphones and other third-party hardware).
SPS 2021
E-Paper THE OFFICIAL DAILY Day 3
The official SPS daily newspaper for you. Issue 3 is also packed full of automation news for you: exciting interviews, new technologies and the latest product innovations. The new interactive e-paper is now available.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
