Xilinx
Intelligent and adaptive solutions
Founded in 1984, Xilinx has developed into a manufacturer of complex and comprehensive hardware and software solutions for electronic systems in many different markets. At SPS, the company will be presenting intelligent and adaptable products for industry and medicine of the future.
Chetan Khona, Xilinx: "For many applications, the trend is moving from the cloud back to the edge."
© Xilinx
The IoT revolution with cloud computing and explosive growth in data volumes has consequences, even if the internet connections are reliable. "Data confidentiality is a top priority, data must be transmitted securely, latency and response must be appropriate to the application, and the cost of data management must not exceed the desired scope - new systems must be easy to integrate into existing ones," explains Chetan Khona, Director Industrial, Vision, Healthcare & Sciences (ISM) at Xilinx. "For many applications, the trend is therefore moving from the cloud back to the edge."
To support this development, Xilinx has optimized its product portfolio for industry and healthcare in terms of adaptability and intelligence. Khona cites the 'Zynq' and 'ZynqUltraScale+' modules, which are optimized for IIoT and HcIoT (Health Care IoT) and form a powerful and scalable hardware basis, as examples. The hardware is complemented by the Industrial and Healthcare Stack, an interdisciplinary offering from Xilinx and its partners for the edge. In addition to the hardware, the stack includes embedded software for safety and security as well as for networking, intelligent control and embedded vision through to artificial intelligence at the edge. "We have developed the special 'Whole Application Acceleration' process for this purpose, which significantly outperforms the AI inference previously used in the industry," explains Khona. In an image processing application, for example, the throughput increases from the usual CPU-based processing of 6 frames/s to up to 60 frames/s if the CPU is supported by Xilinx components.
In addition to its chips, Xilinx has developed the 'Alveo' series of accelerator cards in order to be able to quickly process and store the huge amounts of data that are generated everywhere. They can be used to build domain-specific architectures on which changing algorithms run. In addition, a wide range of pre-programmed applications is already available for them. Xilinx also works with Amazon Web Services, Microsoft, Google, IBM and Alibaba to offer its customers cloud services.
According to Khona, such a comprehensive product range is urgently needed today because electronics development has changed completely. "What is needed are scalable platforms, so-called domain-specific architectures (DSAs), which are tailored to the respective application area with adaptable hardware solutions and can be easily adapted to changed or increased requirements. Khona cites FPGAs, SoCs, MPSoCs, RFSoCs and the new Adaptive Compute Acceleration Platforms (ACAP) as examples of his company's adaptable hardware. The necessary development tools Vivado and PetaLinuxSDX as well as the new Vitis and Vitis AI tools are available.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
