Engineering
Quelle: Siemens | Inka Krischke,
Framework in the cloud
With 'TIA Portal in the cloud', Siemens is expanding the options for using the engineering framework more flexibly in the various phases from planning to engineering and commissioning.
© Siemens
The possibilities offered are based on the main features of 'TIA Portal Version V15.1' with additional available options such as simulation of the application in the cloud environment with the help of 'S7-PLCSIM Advanced', project planning of visualizations with HMI panels up to PC-based runtime systems and the integrated Sinamics drive portfolio. The use of the 'TIA Portal' in the cloud enables web-based access to pre-installed environments, with any hardware, without installation, independent of time and location. This reduces the effort required to test 'TIA Portal' innovations. The integration of different PC and tablet hardware into the development process of machines and systems increases flexibility and reduces engineering hardware requirements. Local installation on the devices is not necessary as access is web-based. In addition, the scalability of the cloud architecture enables individual adaptation to the user's requirements. The central storage of project data in a cloud-based file share enables fast access, regardless of where the user is located. It also simplifies the distribution of project data within the team.
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
Siemens
For personal use
Siemens operates vertical farming for its own use at its site in Frankfurt. Siemens technology is used here. What works here on a small scale is also a future field for agriculture in general.
In focus: Agriculture
The e-paper of issue 05/2024
Strategies for the future are one of the topics covered in the current issue of Computer&Automation. Read about the reforms that associations are demanding from politicians, the opportunities offered by technologies such as ChatGPT and SPE and...
