Products of the year 2022
Taxes & rules - The winners
The readers have decided: These are the winners in the Taxes & Rules category.
3rd place - IBHsoftec
With the IBH Link IoT gateway and the pre-installed 'Teamviewer' software, IBHsoftec offers the possibility to access almost all PLC systems anytime and anywhere. Together with TeamViewer, the gateway enables easy access to control systems and their programming. It is a compact device for top-hat rail mounting with four Ethernet ports and a 24 V power supply. According to the provider, this makes complex modem solutions or the use of a PC on site a thing of the past.
2nd place in the Taxes & Rules category
2nd place - B&R
With a ready-made software solution from B&R, machine builders can now implement Pick&Place applications much more easily, according to the provider. The system not only controls the robot itself, but also coordinates it with other axes, conveyor belts or intelligent track systems. mapp Pick&Place gives the user maximum freedom in designing the process. Any number of delta, articulated arm and scara robots can be used. More...
Sebastian Brandstetter, Product Manager at B&R, accepted the trophy for the software solution and talked about the key features of 'mapp Pick&Place' and the feedback B&R has received so far. Brandstetter also provided insights into the roadmap for the next 12 months.
1st place in the Taxes & Rules category
1st place: Beckhoff - S7 communication protocol for TwinCAT 3 'Twincat S7 Communication' (TF6620)
© Beckhoff1st place - Beckhoff
A new add-on now provides the additional option of communicating easily with S7 controllers from Siemens using the 'Twincat' automation software from Beckhoff. 'Twincat 3' offers many options for connecting TCP/IP-based third-party systems to the control program: OPC UA, MQTT, HTTPS and Modbus are just a few of a range of communication protocols. This broad spectrum is now extended by the S7 communication protocol with the Twincat S7 Communication (TF6620) function. More...
Sven Goldstein, Product Manager TwinCAT Connectivity & IoT at Beckhoff, was delighted with the award for the communication protocol and described three important features of the solution and the feedback Beckhoff has received to date. Goldstein also provided insights into the company's future plans.
