Delta Logic
Server for industrial communication
Accon-OPC-Server UA from Delta Logic has been specially developed for the requirements of a Siemens S7 environment. The software enables secure data transfer between OPC server and client as well as S7 PLCs.
Accon OPC Server UA from Delta Logic
© Delta Logic
The software supports the current OPC UA specification 1.04 and has been certified by the OPC Foundation since the end of 2021. The software from Delta Logic is used wherever an OPC UA-compliant interface is required to access the data of an S7 controller, for example for server-client communication in BDE, MES or ERP. The software was developed for use with Siemens S7-300, S7-400, S7-1200, S7-1500 and Siemens-compatible PLCs. Simultaneous two-way communication (read and write) can take place with up to 255 PLCs. Online symbol import from S7-1200 and S7-1500 PLCs is possible.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
IoT
The Greenfield platform
Delta Logic used the 25th anniversary celebrations to present an IoT platform developed jointly with RST Industrie Automation. Delta Logic Managing Director Rainer Hönle explains what's behind it in an interview.
Schildknecht
From Bluetooth to 5G
Radio instead of cables - this topic is occupying more and more machine and plant manufacturers. Schildknecht is presenting new solutions specifically for Bluetooth Low Energy and is also addressing the future topic of 5G.
