Codesys Automation Server
Roland Wagner | Günter Herkommer,
Efficient administration of distributed control systems
With a large number of control systems in the field, it is often difficult to maintain an overview. This is where the 'Codesys Automation Server' comes in: It enables convenient administration of all controllers via the digital image of each PLC in the network.
© 3S-Smart Software Solutions
If you want to know how many robots are working in production at Daimler, you have to go there and count them yourself. The reason: the robots cannot be found and counted in the network as they are generally not connected. Any inkjet printer from a discount store for 80 euros can do this, but most industrial components today cannot. There is enormous untapped innovation potential here!"
Prof. Rainer Draht, Pforzheim University of Applied Sciences: "The manufacturer-independent administration of automation devices is a topic with enormous future potential."
© Pforzheim University
This statement by Prof. Rainer Drath, a renowned digitalization expert at Pforzheim University, is both surprising and sobering. How can it be that expensive industrial devices are not equipped with technologies that we find in the consumer sector today? The question can be answered quickly: until now, the technical prerequisites for this were simply not in place; especially as heterogeneous architectures are usually used in the industrial environment and there have been few truly overarching standards for different device types and units to date. In addition, there are other aspects such as IT security and know-how protection, which are much more critical here than in the private sector.
But first things first: What conditions would need to be in place on the factory floor to give the operator a quick overview of the smart devices in their network? The scenario could look like this: All control systems are integrated and accessible in the company network. This means that all PLCs, robots or intelligent subsystems either have a direct Ethernet connection or can at least be integrated via a corresponding gateway. We are already well on the way to achieving this: almost every current industrial controller is now supplied with at least one Ethernet port, and many devices even have two or more ports - including for Ethernet-based fieldbus connections.
The Codesys Edge Gateway is the communication interface from the control plant to the Automation Server and provides the information for the digital image of all connected controllers.
The next prerequisite: software interfaces for standardized access to the control systems. Many different manufacturers with Codesys-compatible systems use a special service for this, the so-called 'Codesys Gateway'. This is originally responsible for communication between the programming tool and the runtime on the device. It provides important functions, such as scanning the local network for compatible controllers or downloading applications.
This service typically runs on workstation PCs under Windows, but it can also be installed directly on the compatible devices as part of the runtime system. Appropriately equipped controllers thus become a router to other subsystems with Codesys runtime systems in the network. If the service is expanded to include common communication protocols for Industry 4.0 applications, it can provide information from connected controllers - for example, for the overview of devices in the company network mentioned at the beginning. In effect, the service implements edge computing, i.e. according to Wikipedia's definition, it moves "data and services away from central nodes [...] to the outer edges of a network" so that they are available for cloud-based systems. Suitably equipped devices thus become edge controllers, enabling the use of cloud technologies in industrial manufacturing.
The platform for Industry 4.0 administration
Once the information on the control landscape is available at the 'border' to the Internet, all that is needed is a suitable counterpart to administer the information and make it available for use - i.e. server software such as the upcoming 'Codesys Automation Server'. Installed on a private or public cloud server, this software provides an overview of all Codesys-compatible controllers in the network. To do this, the Edge Gateway first establishes the connection to the server, whereby the communication is encrypted and signed in every case. This means that certificates are required in pairs both on the server side and on the Edge device to enable mutual access.
Whether the edge service runs on a powerful PLC or a separate computer is irrelevant for the function. Once the connection is established, the Automation Server creates a so-called 'digital twin' for each device found, which represents the physical device: Are they modular PLCs, intelligent drives or panel controllers? Are all devices active without faults? Which applications and versions are they running? In addition, the Automation Server can read or write control data in order to parameterize the device or application for a very specific task or a special place of use.
For example, it could be that the same controller with an identical application is used several times in different system units: whether a printing unit of a sheet-fed offset press prints cyan or black is only determined by the filling of the color or by the IP address of the physical controller. Nevertheless, unit-specific parameters can be relevant - such as the ink moisture, which can differ from printing unit to printing unit. The same applies to many identical controllers in a commercial building: where these controllers are used - i.e. in which specific room or floor - or which additional tasks they are to perform for a room, can be defined by corresponding parameters. A commissioning engineer can set such parameters directly in the Codesys Automation Server for the task on site - completely without the IEC 61131-3 source code or the programming tool.
Added value through digital twins
How does a system operator benefit from a digital image of their control systems? No longer having to count them, but automatically receiving a complete overview is already an added value in itself. But that's not all! If the operator knows the status of all integrated devices, he can react to the failure of a control unit even if production does not stop in the event of a failure or no corresponding alarm message has been generated.
Overview of available Codesys Automation Server applications and their use in the field: Applications, devices and parameter sets can be conveniently managed via a web browser.
If, for example, the control system for a mobile machine unit whose function is not used on a daily basis fails, the operator of the machinery can still see this immediately in the Automation Server. This is particularly valuable if the machine in question is in use somewhere in the field. The topology view provides a quick overview of not only the number but also the position of the respective devices in the network. This is because the Automation Server knows all the integrated controllers and - unlike conventional routers - provides really useful and meaningful information. This means that not only the IP address is displayed, but also, for example, the current software version for each device, the active application or the application parameter sets associated with the device.
In this way, the machine operator immediately recognizes which control unit should be brought up to date with a software update. Today, the motto "Never change a running system" is still often applied - even if an update could improve the functionality, performance or protection of the application. This is hardly surprising: maintenance personnel usually have to be directly on site at the machine for an update and physically connect the programming tool to the controller. The Automation Server also provides a remedy here: all control projects can be stored on the server as so-called boot applications - i.e. as executable files for the respective device platform.
This boot application then only needs to be transferred from the server to the target system for the mandatory update at some point. The added value is all the greater if an update - as in the case mentioned above - is to be rolled out to many similar devices at the same time. The update is then carried out from a central location to all selected controllers - if desired, also at night and automatically by script.
The steps for connecting devices
So what exactly needs to be done to be able to manage controllers via the Automation Server? First of all, a sufficiently powerful edge gateway is required that establishes the secure connection to the server via HTTPS or TLS. This can be a high-performance PLC with a Codesys runtime system in the network or a dedicated edge controller that performs encryption and signing via X.509 certificates. By downloading the project to the target controller, the device is then automatically registered in the server. In addition, each controller can be registered manually by entering a corresponding device ID or by scanning a barcode. A corresponding plug-in in the development system stores a PLC application directly on the Automation Server as a boot application. This can then be rolled out directly via the server's web interface, for example using a tablet or smartphone.
Furthermore, the user can configure various parameter sets for individual tasks, such as data exchange via OPC UA or visualization, in the symbol configuration of the development system in their project. With such a data set, they can also specify exactly which application variables are available as parameters in the server and should be read or written directly from the server interface. This enables a commissioning engineer on site to assign the physical controllers to their actual location and specific task via a browser. Because the older Codesys devices of generation V2 are also recorded via the gateway, they can also be registered and managed in the server. However, due to the lack of communication encryption, such controllers cannot be used as an Edge at the same time.
Author:
Roland Wagner is Head of Product Marketing at 3S-Smart Software Solutions.
The Codesys Automation Server
In addition to the described features for server-based administration of Codesys controllers, the upcoming Automation Server will successively provide various other useful functionalities - including, for example:
  • Convenient administration and assignment of user profiles and security certificates
  • Backup and restore of control applications
  • Central implementation of continuous integration processes to increase the quality of application software
  • Storage and evaluation of controller data
Circuit breakers
The transparent power supply
Transparency in the production process requires the continuous recording of measured values and their forwarding to the control systems. The example of a modern automatic circuit breaker shows what this can look like in the field of 24 V (DC) power...
Industry 4.0
The 'SEAP 4.0' project
I4.0 has been accompanying automation technology since 2011. The main results of this work are the Reference Architecture Model Industry 4.0 (RAMI 4.0), the I4.0 component and the asset administration shell. The concept of the asset administration...
Smart cameras
Optimized production
Covering three tasks with just one visualization system - this was the requirement when redesigning a bag filling system for the food industry. Smart camera technology makes it possible.
Control software / simulation
Automate the test
Machine and system manufacturers are increasingly moving towards simulating control software before commissioning in order to correct any errors in advance. Instead of carrying out the tests manually as before, it is advisable to switch to an...
Industry 4.0
From the sensor to the cloud
How can sensor data be uploaded to a cloud platform? At SPS IPC Drives, Hilscher is presenting a technology platform that is intended as a system solution for OEMs and also includes the aspects of diagnostics and maintenance.
Industry apps
Digital prototyping
Digitization projects are often viewed with scepticism. This makes it all the more important to involve employees in new workflows and processes right from the start. Rapid prototyping methods and processes are suitable for this - for example when...
Safety mats
Operation by foot
Safe area monitoring combined with active machine operation - this is exactly what a dynamic safety mat offers. Workers can trigger defined actions using their feet and virtual buttons. Their hands remain free, enabling new operating concepts.
Industrial PCs
20 % more productive
Flying chips, vibration and splash water: industrial PCs have to cope with such influences in the production of clamping tools. With BDE and CAD software on board, they increase productivity by 20 %.
