SEW-Eurodrive at the SPS 2023
Control platform supports hybrid approach
SEW-Eurodrive has a new control platform that supports the hybrid approach of running two operating systems on one hardware.
© SEW-Eurodrived
The 'Movi-C' controller type UHX86A expands the control portfolio of the 'Movi-C' modular automation system in the upper performance range. Variants are available with different Intel processors, either Celeron or Core i3 to i7, in order to be able to adapt the hardware to the application in terms of performance. There are also several options for the fieldbus variant: The device from SEW-Eurodrive can be integrated into Profinet IO, Ethernet/IP and Modbus TCP infrastructures. There is also a choice of capacities for the main memory, the hard disks and the NVRAM memory for persistent data storage. The standard version includes an Ethercat interface (or SEW's own SBusPlus protocol) for connecting frequency inverters from the modular automation system for motion control as well as a variety of other Ethercat devices.
Hall 3A, Stand 411 + 711
SEW-Eurodrive
Electric, efficient, energy-saving
The storage and retrieval machines in a high-bay warehouse have been equipped with energy storage systems that reuse braking energy and reduce peak loads. This solution was the result of cooperation between the plant manufacturer Lödige Industries...
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
SPS 2024
Automation meets innovation
SPS - Smart Production Solutions will take place in Nuremberg from November 12 to 14. Once again this year, organizers and exhibitors will pick up on the trends in the automation industry and present suitable solutions. The introduction of IT into...
