Embedded Box PCs
Use in the machine and company network
Despite its compact dimensions of 100 mm x 115 mm x 31 mm (WxDxH), the Hygrolion 67 embedded box PC has everything necessary for easy integration into the respective network, according to the manufacturer ICO.
Two Gbit LAN connections and an additional WLAN connection enable combined use in the machine and company network or direct access to the internet. The computer can receive measurement data via the two integrated USB-C and USB-A interfaces as well as via Bluetooth 4.0 and, for example, process the data as an IoT gateway and forward it to the cloud server. Two additional antennas increase the range of the Wi-Fi. The VESA mounting points allow it to be attached to monitors or displays or even directly to walls or machines. An additional display port can also be used for control or monitoring tasks. An Intel Celeron N3350 with a clock speed of 1.10 GHz is used as the processor. However, the processor can also dynamically increase the computing power to up to 2.40 GHz, which is sufficient for most IoT tasks. The processor is supported by 4 Gbytes of RAM and a 64 Gbyte eMMC for the operating system and data. The computer is equipped with IP67 protection for the necessary robustness.
