Pyramid Computer
AI-compatible workstation
With the 'AKHET Tower' series, Pyramid Computer has an AI-compatible workstation in its portfolio.
All elements can be customized according to requirements. The workstation from Pyramid Computer is adapted to demanding tasks for medium to high graphics and AI workloads in professional environments. The workstation has been equipped with a specially developed fan concept in order to ideally dissipate the resulting waste heat from the housing. With minor modifications, the series platform can also be used in industrial environments. Depending on the version, there is space for up to two of the largest consumer graphics cards available. Thanks to a special bracket, these are protected against transport damage and can be installed before delivery. The components play a decisive role, especially when it comes to AI. According to the manufacturer, the next two generations of graphics cards will also fit easily into the housing to upgrade the PC. Alternatively, the series is also available as a 19-inch rackmount solution.
