BMC Solutions
Fanless industrial PC for edge computing
With the 'MIC-785', BMC Solutions is expanding its portfolio with a compact industrial PC for demanding edge computing applications. The platform is designed for data-intensive scenarios such as machine vision, industrial control and automation and is based on the latest AMD AM5 architecture.
© BMC Solutions
Inside, either processors from the Ryzen Embedded 7000/9000 or EPYC 4005 series are used. These offer high computing and graphics performance and are particularly suitable for applications with high data volumes and real-time requirements. The system also supports several independent displays and is therefore designed for visualization and monitoring tasks. A key feature of the IPC is its completely fanless design. In combination with an IP40-protected housing, the system is designed for use in harsh industrial environments. Extension technologies such as FlexIO, iDoor and iModule allow the system to be adapted to specific requirements. The single-sided I/O design facilitates integration into existing systems and supports structured cabling, particularly in control cabinet construction. A selection of interfaces is available for system integration, including Gigabit Ethernet, USB and serial communication interfaces. This is complemented by flexible storage options with NVMe and 2.5-inch drives. The input voltage range of 12 to 36 V(DC) enables use in both stationary and mobile applications.
SSV
AI-based Continuous Monitoring
Each connected module now includes integrated AI functions: while this is standard in today’s smartphones, it remains rare in automation. Yet, such AI could serve as a foundation to detect communication issues caused by cyberattacks in real time.
