ICO
Embedded PCs based on Mini-ITX mainboards
The space-saving Mini-ITX solutions from ICO Innovative Computer are based on Intel or AMD processors.
© ICO
With the Intel version, there is a choice between the Picosys 4615 and the Picosys 4615A. While the Picosys 4615 embedded PC works with an Intel Core i5-6500TE 2.3 GHz processor, the Picosys 4615 has an Intel Core i7-6700TE 4/8 2.4 GHz processor. Both systems run with 16 Gbytes of RAM in the basic version, which can be expanded up to 32 Gbytes. The core of the AMD counterpart Picosys 4211 is an AMD Ryzen V2748 processor with 2.9 GHz. This version also comes with 16 Gbytes of RAM as standard. All embedded PCs mentioned have a fast 256 Gbyte SSD, which provides sufficient storage space for common applications. Thanks to an x16 PCI Express slot, it is possible to integrate a powerful graphics card. A DVI and a DP interface are available for graphic output. There are also two Gigabit LAN ports, six USB 3.0 ports and two serial ports, one of which can be used as an RS232/RS422/RS4856 port.
Bressner
Edge AI GPU computing platform
The Nuvo-8108GC-QD from Bressner Technology is an edge AI GPU computing platform with Intel C246 chipset that supports an NVIDIA RTX A6000 or RTX A4500 Amp graphics card and an Intel Xeon E or 8th/9th Gen Core CPU.
