Concept International
Individually configurable
The 24 inch/60 cm All-in-One PC DT524T Black from DT Research is certified in accordance with EN 60601-1 and is therefore subject to stricter EMC controls than the usual CE certification.
Its shock-resistant chassis is resistant to cleaning and disinfectants thanks to its aluminum alloy, its front is made of sturdy Gorilla Glass and has a 10-point touchscreen. The anti-glare display of the Panel PC shines with 300 cd/m². In addition, the capacitive touchscreen is firmly connected to the LED panel using a special bonding process.
Industrial customers can choose between full HD or 4K resolution. The device is optionally equipped with an integrated RFID reader for fast, chip-based login. The 'data center' of the tablet PC comes from the Intel Core i family: either as a dual-core Celeron or as a QuadCore i5 or i7 variant. Depending on the model, the RAM can be upgraded to up to 16 Gbyte and the local memory can be increased to up to 1 Tbyte with the help of an SSD.
