Embedded systemsNew products at embedded world 2018
From February 27 to March 1, 2018, the Nuremberg exhibition halls made room for everything to do with embedded systems technology. Computer&AUTOMATION presents a selection of new products that were on show at the stands of the 16th embedded world.
2 of 30
18_Panel PC Inox-F15C-ULT3 from Comp-Mall
© Comp-Mall
The Inox-F15C-ULT3 panel PC from Comp-Mall is a fanless, completely enclosed model in a stainless steel housing (SUS304). According to the manufacturer, the device is suitable for extreme conditions thanks to protection classes IP66 and IP69K and an operating temperature range of -20 to +50 °C. It is based on the Intel Core i5-6300U or Celeron 3955U processor, is equipped with up to 32 GB DDR4 SO-DIMM and offers mSATA, M.2 and an externally accessible bay for SATA SSD. The 15-inch LCD screen has a resolution of 1024 × 768, a brightness of 450 cd/m², a contrast of 800:1 as well as a 7H scratch-resistant, completely flat, groove-free display surface and a PCT or resistive touchscreen. All interfaces are accessible via M12 screw connections at the rear. The following connections are provided: 2 × USB 2.0, 2 × COM, 2 × GLAN and DCV input. Waterproof connection cables are available for USB, COM and GLAN. Two PCIe mini-card slots and the installation depth of 18 mm extend the range of applications. A supply voltage of 9 to 36 V(DC) is required - a waterproof power supply unit is available as an option. VESA 100 is designed to allow flexible mounting options on a swivel arm, base, table, wall or panel. The dimensions are 414 mm × 329 mm × 52 mm.
2 of 30
