Box PCs
Quelle: Comp-Mall | Lukas Dehling,
Fulfill MIL-Std-810G standard
With the new Box-PC model Tank-870e-H110, Comp-Mall offers a fan-free system for mounting in a cabinet, on the wall or in a vehicle. The system is specially designed for applications in the field of machine control and automation technology.
© Comp-Mall
According to the manufacturer, the computer is largely vibration and shock resistant thanks to its robust design and complies with MIL-Std-810G. It can therefore also be used as a control unit in vehicles. The model is available in three variants with 1× PCIe x16, 2× PCI or 1× PCIe x16, 1× PCIe x4, 1× PCI or 3× PCI slots. There is also 1× full-size PCIe Mini slot and 1× full-size PCIe Mini slot with mSATA. The box PC is available with the Intel Core i7-6700TE (2.4 GHz, quad-core) or Intel Core i5-6500TE (2.3 GHz, quad-core), Intel H110 chipset and two 260-pin sockets for DDR4 SO-DIMM up to 32 GB. Two independent display outputs and other interfaces are available: VGA, HDMI, 2× PCIe-GbE-LAN, 4× USB-3.0, 2× isolated RS422/485, audio, 2× PCIe-Mini. The system operates at temperatures from -20 to +50 °C. Its dimensions are 255 mm × 190 mm × 133 mm.
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
