Aaronn Electronic
First own box PC
Previously known as a distributor and integrator of industrial PCs and embedded systems, Aaronn Electronic is presenting its first in-house developed box PC at the SPS. Florian Haidn, Managing Director of Aaronn Electronic, explains what's behind it.
Florian Haidn, Aaronn Electronic: "Box PCs are becoming increasingly compact with more I/Os in the smallest of spaces."
© Aaronn Electronic
What trends does Aaronn Electronic see in box PCs?
Florian Haidn: Box PCs are becoming increasingly compact with more I/Os in the smallest of spaces. They are also becoming more powerful and more individual: because there are so many different applications, customer-specific adaptations are often required to meet the requirements. Interconnectivity is also a decisive criterion, especially for gateways.
What prompted Aaronn Electronic to develop its own box PCs?
Florian Haidn: There is already a wide range of different box PCs for various applications. However, customer-specific adaptations are usually only possible for larger quantities. This also requires a complex coordination process between the customer, system integrator and manufacturer.
The A2I box from Aaronn Electronic, on the other hand, is a completely modular and therefore particularly flexible alternative that is geared towards the customer's requirements.
What are the unique selling points of the box PCs?
Florian Haidn: The A2I box has a modular design and therefore remains up-to-date for years: if there is a new generation of modules, for example with more powerful or cheaper CPUs, the CPU module can be replaced without having to redesign the entire box. The base consisting of the carrier board with the I/Os and the housing remains the same.
With dimensions of 142.4 mm x 103 mm x 54.5 mm, the fanless housing is very compact. Nevertheless, it offers various interfaces: DisplayPort, 2 x RS232, 2 x USB 3.0 and 2 x Gigabit Ethernet. The range of interfaces can be expanded as required via mPCIe slots, for example to include connection via CAN, Profibus, WLAN or RS485.
However, the most important unique selling point is the ability to make customer-specific adaptations, even for smaller quantities. These adaptations are carried out at Aaronn Electronic. The fact that it is an in-house product means that the company has all the levers in its hands and can act independently, quickly and flexibly.
Can the box PCs be used as edge controllers?
Florian Haidn: The A2I Box can be seamlessly integrated into a network and takes on a wide range of tasks on the machines that go beyond machine control. For example, it can pre-process, filter and, if necessary, analyze data on the machine using machine learning and AI in order to make quick decisions on site. This ensures that only selected data is sent to the cloud, eliminating potential security risks and reducing costs.
How can the Box PCs be customized?
Florian Haidn: It starts with your own company logo on the box. Interfaces that are not available as standard can simply be added using mPCIe cards: RS485, CAN, Profibus and additional network interfaces. Deep learning and AI applications can also be implemented using mPCIe cards from Intel subsidiary Movidius.
We are happy to create specific images of operating systems and install them - also together with customers. Not only the box PC itself, but also the surrounding packaging, labels and cables can be customized. The entire package can be designed according to the customer's requirements and wishes.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
