Cincoze
Embedded computers for edge computing
The Cincoze embedded computer range consists of seven main variants. All variants offer robust construction, fanless design and modular extensions and comply with international manufacturing standards such as ROHS, CE, FCC and ICES-003.
© Cincoze
Certifications such as MIL-STD-810G, E-Mark and EN50121-3-2 in combination with protection devices against reverse polarity, overvoltage, overcurrent and ESD and with a range of performance options and comprehensive expansion options enable the embedded PCs to be used in all industrial environments. A 'newcomer' is the DV-1000 from Cincoze, which works in a wide operating temperature range (-40 to +70 °C). It is equipped with an Intel Core processor from the i-series and DDR4-2666MHz RAM up to a maximum of 128 Gbyte and has the most important inputs/outputs. These can be optionally upgraded to individual requirements using CMI, CFM and MEC expansion modules.
QNAP
Virtualization of network functions
QNAP has introduced the new QuCPE-303x Network Virtualization Premise Equipment. It combines network function virtualization, QuWAN SD-WAN and the AMIZ cloud management platform with Intel hardware network acceleration technologies.
