Acceed
Box PC with flat-top cooling to prevent heat build-up
The Nuvo-9531-FT box PC from Neousys belongs to a new category of fanless computers that use a flat heat sink for passive heat dissipation.
© Acceed
The temperature range of the model series available via Acceed extends from -25 to +60 °C. The computer is designed for installation in closed cabinets, waterproof boxes or even explosion-proof housings. Thanks to the flat heat sink with the heat conducting pad on the top, the heat generated during operation can be effectively dissipated to the outer surface of the housing. The box PC supports processors of the 14th generation from Intel with up to 24 cores/ 32 threads. Extensive I/O functions such as four 2.5 GbE interfaces with optional PoE+ PSE and four USB 3.2 ports can be used to connect multiple cameras, for example. Other features include an M.2 socket Gen4 for connecting an NVMe SSD with read/write speeds of up to 7000 Mbit/s, two Mini PCIe slots and an M.2-E slot for installing WiFi or 5G/4G communication modules as well as a hot-swappable hard disk slot.
Advantech
Edge AI HPCs for Vision AI and GenAI
Advantech has announced the 'AIR-410' and 'AIR-420', next-generation compact Edge AI high performance computers (HPCs). Combining AMD Ryzen 7000/8000/9000 series processors, scalable GPU support and Advantech's 'Edge AI SDK' software, the systems...
