Acceed
Despite heat and dust in the field
The embedded computer 'NRU-160-FT' from Neousys can be installed in dustproof or waterproof housings and uses their walls to dissipate heat.
© Acceed
With the Jetson Orin AI module from Nvidia, the device achieves up to 100 INT8 TOPS and can simultaneously process up to 18 full HD video streams with a power consumption of around 25 W, according to distributor Acceed. The embedded computer is designed to support developers and integrators in the fields of robotics, automation, vehicle and traffic technology, agricultural and construction machinery. The compact controller measures 199 mm × 136 mm × 49 mm and works with either the Jetson-Orin-NX or the Orin-Nano from Nvidia. Both variants use CUDA and tensor cores to execute neural networks directly on the device. The Conduction Cooling concept uses a flat passive cooling profile that dissipates heat to a mounting surface so that the electronics remain stable even at high ambient temperatures. The operating range extends from -25 to +70 °C without clock reduction in 25 W mode.
Advantech
Edge AI HPCs for Vision AI and GenAI
Advantech has announced the 'AIR-410' and 'AIR-420', next-generation compact Edge AI high performance computers (HPCs). Combining AMD Ryzen 7000/8000/9000 series processors, scalable GPU support and Advantech's 'Edge AI SDK' software, the systems...
Neuron Automation
Functional Safety - Works!
With the certified safety modular system from Neuron Automation, OEMs can implement functionally safe control solutions faster, more flexibly and more cost-effectively - from hardware and firmware to the application. Functional safety 'in time', 'in...
