Acceed
30 W Energy consumption
With the NRU-120S AI platform with integrated 'Jetson AGX Xavier' module from Nvidia, Acceed offers a solution for future edge computing applications in AI.
© Acceed
The compact device with a robust, fanless design offers the same GPU performance as a mainstream GPU PC with 120 W at 30 W power consumption. The controller has four PoE+ interfaces, two 2.5-inch hard disk bays and additional I/O connections. The four Gigabit network ports with PoE can supply 25.5 W of power to connected PD devices (powered devices).
For data storage, Acceed 's 'NRU-120S' is equipped with an M.2 socket (2280 NVM Express) for fast SSD read and write and two hard disk bays in addition to the 32 Gbyte eMMC on the Xavier module. The two hot-swappable 2.5-inch slots for SSD or HDD are accessible from the front. The device's internal mini PCIe socket can accommodate a WiFi or 4G module, for example. The PPS input enables cross-platform synchronization based on the common time reference provided by the GPS module.
MVTec
The 'eye of production'
Machine vision makes a significant contribution to the end-to-end automation and optimization of production chains. If artificial intelligence methods such as deep learning are used here, process efficiency can be further increased.
Compar
Artificial intelligence for image analysis
For soldered connections on printed circuit boards, the switch to lead-free solder causes increased failure rates. Quality control must therefore be improved. However, conventional methods with camera-supported automatic image evaluation quickly...
Deevio
End of manual visual inspection?
The widespread industrial use of artificial intelligence is still a long way off. Yet self-optimizing deep learning solutions are an important milestone on the way to the smart factory, which consists of AI-based production facilities and logistics...
DFKI
Research building opened in Bremen
One of the most important research institutions in Germany in the field of artificial intelligence has opened a new building in Bremen. The DFKI intends to use the extension to advance research into future topics, according to a press release.
