Fraunhofer IPMS
Meinrad Happacher,
Wireless TSN by light
Deterministic and real-time capable data transmission via TSN. In addition to traditional Ethernet cabling, WLAN, 4G/LTE and 5G are being discussed for data transmission. But there is another way: using light, as Fraunhofer IPMS will be demonstrating at the trade fair.
The LiFi hotspots at the trade fair: TSN via optical transmission - an alternative for mobile applications.
© Fraunhofer IPMS
Time Sensitive Networking (TSN) extends existing Ethernet standards to include mechanisms for deterministic and real-time-capable data transmission via a switched network. At present, real-time communication is based on wired Ethernet transmission media - a clear limitation for mobile applications such as robots, modular and flexible production cells and other automation technology applications. Deterministic and real-time-capable wireless transmission is also subject to clear limitations due to the properties of the transmission medium. Depending on the application, a defined time budget is available for the transmission path between transmitter and receiver - including processing time. With today's (4G/LTE, WLAN) or the future wireless standard 5G, the required latency times from automation in the millisecond range and faster cannot be reliably achieved.
The Fraunhofer Institute for Photonic Microsystems therefore favors Li-Fi technology. Li-Fi HotSpots use the spectrum of light instead of radio to transmit data. Compared to radio, optical technology is fundamentally safer from electromagnetic interference. It is tap-proof and also real-time capable in the microsecond range. These factors predestine optical communication for industrial use. The local diversity also simplifies network planning, eliminating the need for time-consuming antenna planning and alignment.
At the trade fair, Fraunhofer IPMS will be demonstrating that Time Sensitive Networking can already be implemented today without cables. In addition to TSN IP cores for automation technology applications, Fraunhofer IPMS also develops wireless optical communication solutions for industrial applications.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
