Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
© Delta Logic
The online import of symbols for TIA Portal V19 is also possible. The software from Delta Logic enables secure data transfer between OPC servers and clients as well as Siemens controllers. The current OPC UA V 1.04 specification and symbolic access are supported. The update also offers support for Siemens S7-1200 controllers with firmware 4.6.1 and S7-1500 CPUs with firmware 3.1.2.
Since version 1.3, it is also possible to use virtual devices. This allows users to use virtual variables within the OPC UA server that are not assigned to a specific hardware device, for example. Changes in OPC communication can thus be tested in a secure environment without touching the production system. If the test is successful and runs as desired, communication with the 'real' controller can be resumed.
IoT
The Greenfield platform
Delta Logic used the 25th anniversary celebrations to present an IoT platform developed jointly with RST Industrie Automation. Delta Logic Managing Director Rainer Hönle explains what's behind it in an interview.
Schildknecht
From Bluetooth to 5G
Radio instead of cables - this topic is occupying more and more machine and plant manufacturers. Schildknecht is presenting new solutions specifically for Bluetooth Low Energy and is also addressing the future topic of 5G.
