Radio connections
Quelle: HMS Industrial Networks | Inka Krischke,
Supports Bluetooth and WLAN
HMS Industrial Networks is launching an improved version of the 'Anybus Wireless Bridge'. The Anybus Wireless Bridge II enables a wireless connection with a maximum range of 400 m and supports both Bluetooth and WLAN.
© HMS Industrial Networks
It replaces the Ethernet cable, particularly for applications in harsh environments or areas that are difficult to access: depending on the requirements of the network architecture, it can be used as a cable replacement for point-to-point connections or as an access point. It is commissioned using a push button or the integrated web interface. The Wireless Bridge II uses the same wireless technology as the Anybus Wireless Bolt, a wireless gateway that is mounted directly on the machine and enables wireless system solutions. It is suitable for transmitting Industrial Ethernet standards such as Profinet, Ethernet/IP, Bacnet/IP and Modbus-TCP via radio. The device has one M12 connection each for power and network and complies with protection class IP65.
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
