Helmholz
Solution for simple machine networking
Helmholz presents the new 'Wall IE Compact' version of the industrial NAT gateway. The easy-to-configure gateway is installed once and permanently between the machine and the production network.
NAT mode allows machines to be transparently integrated into the factory network without having to change the machine's IP addresses. The NAT operating mode enables address translation and uses firewall rules or packet filters to restrict access to the automation network behind it. The 'Wall IE Compact' from Helmholz can therefore also be used as a conduit for a new network segment ('zone') to establish secure communication in accordance with the IEC 62443 security standard. The gateway supports transmission rates of up to 1000 Mbit/s for both the factory network and for machine communication. The web interface does not require complex and oversized JavaScript and CSS frameworks.
