Kontron
Low code application for interface integration
The latest version of the integration solution 'FabEagle Connect' from Kontron now also supports user groups with little programming experience thanks to a web client with a low-code approach.
© Kontron AIS
The open and flexible integration solution FabEagle Connect from Kontron realizes the networking of various interfaces of machines and systems in production with IT systems. With the current version 2, the software has been expanded to include a web client for easy configuration of existing interfaces. These are provided clearly in the form of components which, in conjunction with dialogs, enable simple configuration of standardized interfaces such as OPC UA, REST, TCP IP or MQTT. Programming can be completely dispensed with if required. Thanks to guided configuration dialogues and a topology view of all linked components, interfaces between plants, databases and cloud systems can be implemented after just a few minutes of training. The import and export of existing configurations allows them to be duplicated and implemented in new systems. The integrated user administration of the web client protects against unwanted access and adjustments. The logging of events means that the causes of errors or disconnections can be traced permanently at any time.
Kontron
AI-based automatic translation
With a multilingual function, Kontron AIS extends the digitization solution 'EquipmentCloud' and thus enables the automatic AI-based translation of static texts into more than 28 languages for easy and fast international communication.
Lapp
Decentralized switches with IP67 protection
Lapp is launching two switches for use outside the control cabinet: thanks to IP67 classification, the Etherline Access PN IP67 Profinet switch and the Etherline Access U IP67 unmanaged industrial Ethernet switch are suitable for use directly in the...
Kontron
5G module production entirely in Europe
Kontron has announced that it will manufacture its 5G modules entirely in Europe in future. In doing so, the company wants to underline its commitment to shorter supply chains, Europe's technological sovereignty and the reduction of CO2 emissions.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
