Omnidirectional antennas
Joint for 180° rotation around its own axis
Welotec offers a dual-band WLAN omnidirectional antenna with an articulated joint, a classic blade antenna for 2.4 GHz and 5 GHz WLAN in buildings. The joint allows an angle of 0 to 90° and a 180° rotation around its own axis.
This means that the antenna can always be aligned vertically, regardless of the access point position. The ground plane-independent design provides additional flexibility during installation. The antenna gain is 2.14 dBi in the lower frequency band and 4 dBi in the upper frequency band. The antennas are available with reverse polarity TNC male connector (WAO-2450L-3C000-TNCR0) and reverse polarity SMA male connector (WAO-2450L-3C000-SMAR0).
