ifm at the SPS 2022
IP67 power supply units with IO-Link interface
ifm offers intelligent power supply units that provide the required voltage directly on site.
The power supply units from ifm meet protection class IP67 and can be installed together with other components on the machine or system. Integrated electronic fuses in the power supply units protect the 24 V power supply against overvoltages and short circuits. The output voltages and rated currents of the individual circuits, for example, can be set via the IO-Link interface of the power supply units. Current values for voltages and currents of the individual circuits, input voltage, operating hours, internal temperature, etc. can be read out via IO-Link.
The power supply units are available in two versions with a three-phase or single-phase power supply on the input side. The three-phase device has four output circuits whose maximum current can be set to up to 12 A. The single-phase device has two output circuits with up to 4 A each. The nominal power ratings are 500 W and 300 W respectively.
SPS 2022: Hall 7A, Stand 302
