R3 Communications
Industrial production without cables
R3 Reliable Realtime Radio Communications is presenting its first series products 'Echoring Ethernet Bridge' (EREB) and 'Echoring System on Module' (SoM) at the SPS. They are designed to supplement wired industrial Ethernet networks with equally powerful wireless connections.
The 'Echoring SoM' (left) and the 'Echoring Ethernet Bridge' from R3 Communications
© R3 Communications
Industrial automation applications require critical synchronization of different devices, which in the past was only possible via wired networks. However, Industrial Communication 4.0 can put a strain on cabling: Machines need to be reached even when the transmitter or receiver is in motion; scalability requires a more flexible approach than fixed physical connections; and moving parts are more prone to maintenance issues.
Many companies looking to operate IIoT and Industry 4.0 solutions require wireless networks that match the performance and reliability of existing wired control networks. R3's 'Echoring' achieves real-time performance levels with latencies as low as 1 ms, even in demanding industrial environments. It supports reliable, low-latency wireless M2M communication while achieving similar performance to wired systems.
'Echoring' comprises a range of software solutions in combination with hardware modules, stand-alone devices or reference designs based on Texas Instruments' 'WiLink 8' combined connectivity building block for Wi-Fi and Bluetooth. The products should be easy to integrate into existing networks. The supported industrial communication protocols include Profinet, Profisafe, EtherNet/IP, CIP Safety, UDP, TCP/IP and SafetyNet. Additional tools are available for integration, operation and maintenance of the product range.
Thanks to the source code of the 'WiLink 8', R3 Communications has adapted the 'Echoring' technology to function as firmware on the 'WiLink 8'. Echoring uses a radio technology that provides deterministic access, combined with support for safety levels up to SIL 3, and can be retrofitted into existing industrial hardware and software, thus helping to upgrade previous investments.
The 'Echoring Ethernet Bridge' is housed in an IP65 enclosure and has two M12 connectors for the Ethernet connection and power supply. The Ethernet cable is plugged in and wireless communication is realized via 'Echoring'. The 'Echoring-SoM' offers the entire range of functions on a 30 x 32 mm board for deep integration into the machine. Both products are pre-certified for CE and also enable wireless functional safety applications, such as a portable emergency stop button. Cybersecurity is supported by Olympus Sky.
Arrow Electronics has signed an agreement to offer the full range of 'Echoring' networking products in Europe, the Middle East and Africa (EMEA). Arrow will be present at R3 Communications' SPS stand. As part of the agreement, Arrow will offer a starter kit that allows users to test the performance of 'Echoring' in their own production environment by replacing existing Ethernet connections with the kit's wireless stations.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
