Sensor / actuator communicationStarting signal for ASi-5
At SPS IPC Drives 2018, the AS-International Association will be launching ASi-5 - the completely new generation of the AS-Interface bus system for the sensor/actuator level.
<p><!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:AllowPNG></o:AllowPNG>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves></w:TrackMoves>
<w:TrackFormatting></w:TrackFormatting>
<w:HyphenationZone>21</w:HyphenationZone>
<w:PunctuationKerning></w:PunctuationKerning>
<w:ValidateAgainstSchemas></w:ValidateAgainstSchemas>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:DoNotPromoteQF></w:DoNotPromoteQF>
<w:LidThemeOther>DE</w:LidThemeOther>
<w:LidThemeAsian>X-NONE</w:LidThemeAsian>
<w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
<w:Compatibility>
<w:BreakWrappedTables></w:BreakWrappedTables>
<w:SnapToGridInCell></w:SnapToGridInCell>
<w:WrapTextWithPunct></w:WrapTextWithPunct>
<w:UseAsianBreakRules></w:UseAsianBreakRules>
<w:DontGrowAutofit></w:DontGrowAutofit>
<w:SplitPgBreakAndParaMark></w:SplitPgBreakAndParaMark>
<w:EnableOpenTypeKerning></w:EnableOpenTypeKerning>
<w:DontFlipMirrorIndents></w:DontFlipMirrorIndents>
<w:OverrideTableStyleHps></w:OverrideTableStyleHps>
</w:Compatibility>
<m:mathPr>
<m:mathFont m:val="Cambria Math"></m:mathFont>
<m:brkBin m:val="before"></m:brkBin>
<m:brkBinSub m:val="--"></m:brkBinSub>
<m:smallFrac m:val="off"></m:smallFrac>
<m:dispDef></m:dispDef>
<m:lMargin m:val="0"></m:lMargin>
<m:rMargin m:val="0"></m:rMargin>
<m:defJc m:val="centerGroup"></m:defJc>
<m:wrapIndent m:val="1440"></m:wrapIndent>
<m:intLim m:val="subSup"></m:intLim>
<m:naryLim m:val="undOvr"></m:naryLim>
</m:mathPr></w:WordDocument>
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"
DefSemiHidden="true" DefQFormat="false" DefPriority="99"
LatentStyleCount="267">
<w:LsdException Locked="false" Priority="0" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Normal"></w:LsdException>
<w:LsdException Locked="false" Priority="9" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="heading 1"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 1"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 2"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 3"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 4"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 5"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 6"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 7"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 8"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 9"></w:LsdException>
<w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"></w:LsdException>
<w:LsdException Locked="false" Priority="10" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Title"></w:LsdException>
<w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"></w:LsdException>
<w:LsdException Locked="false" Priority="11" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtitle"></w:LsdException>
<w:LsdException Locked="false" Priority="22" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Strong"></w:LsdException>
<w:LsdException Locked="false" Priority="20" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="59" SemiHidden="false"
UnhideWhenUsed="false" Name="Table Grid"></w:LsdException>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"></w:LsdException>
<w:LsdException Locked="false" Priority="1" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="No Spacing"></w:LsdException>
<w:LsdException Locked="false" Priority="60" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Shading"></w:LsdException>
<w:LsdException Locked="false" Priority="61" SemiHidden="false"
UnhideWhenUsed="false" Name="Light List"></w:LsdException>
<w:LsdException Locked="false" Priority="62" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Grid"></w:LsdException>
<w:LsdException Locked="false" Priority="63" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 1"></w:LsdException>
<w:LsdException Locked="false" Priority="64" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 2"></w:LsdException>
<w:LsdException Locked="false" Priority="65" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 1"></w:LsdException>
<w:LsdException Locked="false" Priority="66" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 2"></w:LsdException>
<w:LsdException Locked="false" Priority="67" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 1"></w:LsdException>
<w:LsdException Locked="false" Priority="68" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 2"></w:LsdException>
<w:LsdException Locked="false" Priority="69" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 3"></w:LsdException>
<w:LsdException Locked="false" Priority="70" SemiHidden="false"
UnhideWhenUsed="false" Name="Dark List"></w:LsdException>
<w:LsdException Locked="false" Priority="71" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Shading"></w:LsdException>
<w:LsdException Locked="false" Priority="72" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful List"></w:LsdException>
<w:LsdException Locked="false" Priority="73" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Grid"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 1"></w:LsdException>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"></w:LsdException>
<w:LsdException Locked="false" Priority="34" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"></w:LsdException>
<w:LsdException Locked="false" Priority="29" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Quote"></w:LsdException>
<w:LsdException Locked="false" Priority="30" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 6"></w:LsdException>
<w:LsdException Locked="false" Priority="19" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="21" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="31" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"></w:LsdException>
<w:LsdException Locked="false" Priority="32" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"></w:LsdException>
<w:LsdException Locked="false" Priority="33" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Book Title"></w:LsdException>
<w:LsdException Locked="false" Priority="37" Name="Bibliography"></w:LsdException>
<w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"></w:LsdException>
</w:LatentStyles>
</xml><![endif]--><!--[if gte mso 10]>
<style>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Normale Tabelle";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman","serif";}
</style>
<![endif]--></p><p>Rolf Becker, AS-International Association: "ASi-5 is our shuttle to digitalization!"</p> © AS-International
