HiveMQ
Gateway for the standardization of industrial edge data
HiveMQ launches 'HiveMQ Edge', an open source software gateway with an edge-optimized MQTT broker.
© HiveMQ
HiveMQ's gateway helps manufacturing companies simplify and modernize their industrial IoT infrastructure by converting proprietary OT protocols such as Modbus and OPC UA to the standardized MQTT format at the edge to enable integration with enterprise and cloud systems. It supports the Unified Namespace architecture, which allows data from different sources to be mapped into a structured and centralized data hub that enables real-time data analytics. The gateway's features include plug-and-play integrations for protocols such as Sparkplug and OPC UA, an edge-optimized MQTT broker to reduce costs, an intuitive user interface and API-based operability, and open source with an extensive SDK for extensibility.
HiveMQ
The standard protocol in the IoT?
In the Internet of Things (IoT), the lean communication protocol MQTT has established itself as an important standard protocol. The use cases for MQTT range from industrial applications and connected vehicles to logistics and home automation.
