Ethercat
Quelle: esd electronic system design | Inka Krischke,
Extend PCs easily
esd has a new PCI Express Ethercat slave interface: The ECS PCIe/FPGA can be used to add Ethercat slave functionality to any PC.
© esd electronic system design
The Ethercat slave controller board is equipped with a Beckhoff IP core. The memory area of the Ethercat slave controller is mapped directly in the PCI Express address space. The 'Ethercat Slave Device' can be configured via 'esd Ethercat Master' or other masters. An Ethercat slave information file (ESI file in XML format) provided as an example is included in the scope of delivery. The slave API library and sample code enable rapid integration and development. To relieve the CPU from copying the output data to the host memory, the interface supports bus master DMA support. With support for MSI (Message Single Interrupt), the interface card is suitable for real-time operating systems such as VxWorks, RTX, RTX64 and others.
Weidmüller
Dr. Sebastian Durst becomes CEO
The Weidmüller Group is strengthening its first management level as of October 1, 2024: Dr. Sebastian Durst, previously Chief Operations Officer, will take over the newly created position of Chief Executive Officer (CEO).
Vega Grieshaber
Chip start-up founded
The start-up milli IC from Karlsruhe specializes in the development of ASICs - and Vega Grieshaber is 'on board' to ultimately develop radar measuring devices with radar frequencies of more than 100 GHz.
Most read
The top articles in July 2024
Innovative spirit and entrepreneurial thinking characterize the most-read articles from July. Find out more about competitive advantages through AI, click through award-winning developments and read more about model-based design and quantum sensor...
